38 or 39 B?
gtk
03-08-2006 14:19:17
We have a styled B whoose serial number begins with 6. It should be a 39 model. Ordered a parts book from John Deere and it shows a 6 speed transmission. Our B has a 4 speed. Was this an option? Could this be an early 39 that they used some 38 parts on? Thanks for any Ideas.
amo
03-08-2006 17:39:17
 Re: 38 or 39 B? in reply to gtk, 03-08-2006 14:19:17
i have a 1943 b and it was a war time tractor with rubber tires and it came with 4 speed transmission, my father had 5 and 6 added about 1951.
230-46bpuller
03-08-2006 17:18:45
I have a 1939 B and it has a 4 speed. It has something bent in the transmission so you can use high range in reverse. I was going to fix it but it's funny to see the looks on people faces when you go flying across the yard in reverse!!
40 B man
03-08-2006 16:54:08
5th and 6th gear could be added to 96000-20????(41-47) tractors that came from factory with 4 speed due to steel wheels. 39-40 B's,4 speed was all you had unless there was an after market road gear.
CLW
03-08-2006 15:30:29
60000-95201 had 4 speed. This was becouse they came with steel wheels and 5th. and 6th. would have been to fast. When rubber tires came out the 4 speed could be modified to add 5th. and 6th. gear. My grandfather had this done to his, altho I am not sure of the year of the tractor. If it was a four speed I guess it had to be a 39-40 model.
CLW
blade
03-08-2006 14:36:48
my book shows serial # 96000 when the six speed came on line
