Fuel shut off not working
Fluggie in IA
03-08-2006 10:41:12
Where's a good place to order a replacement fuel shutoff & sediment bowl for a '47 JD B. Mine won't shut off.
thanks
John Van Valkenburgh
03-08-2006 21:28:00
 Re: Fuel shut off not working in reply to Fluggie in IA, 03-08-2006 10:41:12
I just bought a sediment bowl/shutoff from my local Deere dealer. It was something like $42 or $48. It's a correct replacement but I have noticed that you have to turn the shut off very tight to get it to fully stop the fuel flow. I was surprised at how stiff this is.
John
1953 Model 50
donwisc
03-08-2006 15:38:58
Make sure you have turned the valve far enough to shut off the fuel. Do it at the stop on the valve rather than the rod. What happens is you can get so much slop in the linkage thru wear in the holes and pins that it wont rotate far enough.
I had first hand experience with this on a D where it would limit the fuel to the Carb.
Good luck
jd @antique acres
03-08-2006 10:43:51
I would buy one right from Deere. Around $35.
