JD 2240 draft control
Stephen in SOK
03-07-2006 19:31:31
Can't find manual, can anyone tell me which notch the lever under the seat should be in to activate automatic draft control for plowing? Thank
The Ag Guy
03-08-2006 17:42:47
 Re: JD 2240 draft control in reply to Stephen in SOKY, 03-07-2006 19:31:31
The top notch is Depth Control only (plow stays at same depth regardless of how hard it pulls). Bottom notch is Load Control - plow moves up and down as the load increases and decreases. Notches in-between vary the balance between load and depth control. Probably need to match the setting with your soil type - light/sandy soils, use an upper notch towards depth control to keep it from going too deep. Heavy soils use a lower notch, closer to load control so you can keep moving.
