Deere B Identification
RustyAL
03-07-2006 16:36:15
Just brought a rough looking B home. It has a hole in the serial # plate. How can you tell the year with a meesed up plate? Also it has long levers sticking up on each side of the seat which I do not see in the pictures of B. It is styled.
amo
03-07-2006 20:08:30
 Re: Deere B Identification in reply to RustyAL, 03-07-2006 16:36:15
if you can get the first several numbers you can go to the serial numbers and maybe get a year. the levers are for the cultivator adjustment. a picture would be good. is it styled, has a front grill around radiator, look at some of the old photos and it might help. goo luck
RustyAL
03-07-2006 18:15:01
After looking at the arcives I found some things that may help age this tractor. Cast rims, No starter or place for one, Cast frame, no place for a battery, the long handles that stick over the seat seem to be to lift the implement.manually Alumium tag,
DickD
03-08-2006 01:37:19
 Re: Deere B Identification in reply to RustyAL, 03-07-2006 18:15:01
Sounds like a 41,but I never saw one with a cast frame. Maybe a 43 or 44. Does it have a small radiator cap, like it is pressurized? Does it have 6 forward speeds?
DickD
03-08-2006 18:04:19
 Re: Deere B Identification in reply to DickD, 03-08-2006 01:37:19
It sounds like it might be a 41 How many speeds does it have?
RustyAL
03-08-2006 07:04:43
Dick, It may not be a cast frame. The tractor has a big radiator cap.
van robinson
03-07-2006 20:08:05
I was told the long levers you talk of are for setting the depth of the cultivators. Got a pic of your tractor?
