52 'A' rpm
Dane in PA
03-06-2006 17:38:49
Just got done changing the tires on my 1952 A, so I got it out and checked the RPMs with the new hand held tach. she read about 1300 RPMs so I figured that is about 33% over factory. Guess I'll have to tame it down a little bit for the upcoming pulls, that is if I wanna play fair. :)
Dane
Papy
03-06-2006 22:15:27
 Re: 52 'A' rpm in reply to Dane in PA, 03-06-2006 17:38:49
Frank is getting very close. My book says maximum engine speed, unloaded is 1080 RPM.
F-I-T
03-06-2006 17:52:30
Dane:
It's been a while since I had a late "A" throttle in my lap, but isn't there a high-end stop bolt on the steering quadrant? I'm not sure I remember the all of the speeds, but the rated speed was 975 rpm, and I think the WOT high end was maybe 1100? Someone will check me on that, but the idea is that you need just a bit of overspeed for everything to get together in mesh and underload for the governor to work at its best without hunting. That high speed of 1300 will likely come right down as you place a load on the engine, but when you unclutch from a load with the throttle wide open, it can be a lot of stress on the gear train and engine bottom end. 975 rpm would be the standard speed where you would check the pto delivered horsepower at 540 rpm.
I would check that the governor rod is set correctly (ask if you don't know how) and then set the WOT speed to the right value (again, I think it was 1100 rpm, but I am guessing there), then you'll be ready to put it on a dynamometer and see what you have.
Frank
