A: 2 question's
TEXASJ
03-06-2006 13:15:39
What is the best way to supprt an A model while taking the rear wheels off? were can i find an alt bracket to mount a delco remy?
thanks
Mike M
03-07-2006 06:13:05
 Re: A: 2 question's in reply to TEXASJ, 03-06-2006 13:15:39
Others pretty well covered the supports. Lots of good ideas.
On that alt. conversion you can use the same bottom bracket for a gen. It will line up the same place. You just need to put in a spacer to take up the extra gap. Some car alt. have one on them you can use.An old valve guide works good too. You will need to find a longer top adjustment strap. I just get one from an old junk car and they usually fit ok.
farmerboy
03-07-2006 05:27:33
When I changed a tire on a 1949 A I had, I just put a wheeled floor jack on the drawbar frame to the side of the drawbar I wanted to lift. It lifted fine and seemed quite stable.
I like the idea of taking angle or channel iron and making a custom stand for the frame bolts. that sounds rock solid.
58 820
03-06-2006 21:48:23
measure from the ground up to the implement bolts on the rear of you're axle housing, and add 4-5 inches. Next, get a piece of chanel iron and cut two holes to correspond with the 2 bolt holes at this measurement. Then simply bolt the chanel iron on these 2 bolts. Now you can take of the tires and never worry about the tractor falling. I do this on both sides at the same time.
RalphinWI
03-06-2006 18:25:22
If you are just lifting one wheel at a time with the remaing wheels securely blocked, a good jack will suffice. On my A, which at one time had a one row 127(?) picker, I wanted to switch the wheels from side to side. I used a collection of short 4 x 4's and 6 x 6's. Not the most stable!!!. I changed tires on another A which required a trip to the tire store. I built a "crib" out of 6 - 18" 4 x 4's and 4 - 48" 4 x 4's along with some short 6 x 6 blocks I had around. This was a lot more stable.
G/MAN
03-07-2006 07:32:11
 Re: A: 2 question's in reply to RalphinWI, 03-06-2006 18:25:22
I'm sorry, but you should never trust any jack, no matter how good it is, to support a load while you're working on something, be it a compact car or a bulldozer. I've had to jack and block everything from D-8 Cats on down, and you just don't take that chance. A co-worker of mine was nearly killed one day when a brand-name jackstand that was plenty big for the job peeled in half and collapsed, so I don't even really trust jack-stands.
Glen in TX
03-06-2006 17:41:12
Old larger well casing pipe makes good jack stands along with wood blocks.
Dane in PA
03-06-2006 17:28:58
we just changed the tires on my A and just used my dad's simplex railroad ratchet jack. it worked great for that.
G/MAN
03-06-2006 16:26:05
Good quality jackstands of the proper rating spaced as widely apart as possible.
