1010 Clutch questions
wilamayb
03-06-2006 13:06:41
I am thinking of purchasing a 1010 gas (late model) The clutch is slipping while under load. It will still pull itself. I searched deereparts to find the disc is $455.00 and $40 for pilot and throw-out bearings. Does the clutch have to be set up by a tech? Are there any parts that would be ruined from the slippage that has already occured? Are there any parts that always, or usually have to be replaced when a new clutch is installed. Seems as if a clutch job could easily cost half the value of the tractor! Fill me in on any info you think I should know about the job. Thanks so much.
JDknut
03-07-2006 09:23:42
 Re: 1010 Clutch questions in reply to wilamayb, 03-06-2006 13:06:41
I recently had a clutch job on my 2350 MFWD, that was around $700.00 and they used a Deere clutch and pressure plate, turned out, believe it or nuts, that it was less than some of the aftermarkets. You have it right with the disc, pilot and thowout bearings, but seems high for a disc alone. If it has been slipping a long time, the flywheel and/or pressure plate might be heat damaged, lets hope it is not so. Good luck
wilamayb
03-06-2006 19:32:32
Sorry for taking up the space he sold it before I could get back with him. The good deals go quick.
