70 D rear end shakes
Dan in Ohio
03-05-2006 16:34:14
When I drive this tractor on the road (4th, 5th, and 6th gear) the tractor shakes like the rt. rear wheel has a large flat spot in the tire. What could be causing this? It is a standard with 18.4 x 30 tires inflated to 12lbs.
Mike M
03-06-2006 12:10:24
 Re: 70 D rear end shakes in reply to Dan in Ohio, 03-05-2006 16:34:14
As my tractors sit more and more than they used to I've been having more trouble with flat spots than I used to.
F-I-T
03-06-2006 12:50:11
 Re: 70 D rear end shakes in reply to Mike M, 03-06-2006 12:10:24
As I sit more than I used to, I'm having trouble with flat spots, too, but it's not on my tires!
F-I-T
03-06-2006 06:51:49
Do you have a partial load of fluid in the tire? Maybe it's having a problem with the mass getting up to "rotational velicity"!
I think it's probably all of the reasons listed. A partially flat-sided portion causing it thump, then if you look closely at the space between the center cast wheel and the rim and measure it all the way around, you might see that the lugs favor one side so the wheel runs out of round. If you make some calculations to determine the short side and long side, you might use some spacers like some hard wood dowels to get the wheel re-centered. I worked on our "road" tractor years ago and got it to where it ran very smooth.
So, check for an off-center wheel to rim gap and see if the rim has any squirmy run out along its edge as well.
Frank
BushogPapa
03-05-2006 20:34:09
Dan, some tires will take on a "flat spot" that may take 30 minutes to disappear after you start driving ...
Could be this is what is happening....
PeteNY
03-05-2006 20:27:12
Dan, do you have the rim on evenly? It is common to get some wedges tightened up too much too soon so that the rim is actually at an angle. Have someone drive behind you and sse if it wobbles unevenly. Pete
Dan in Ohio
03-06-2006 05:00:51
 Re: 70 D rear end shakes in reply to PeteNY, 03-05-2006 20:27:12
Thanks for the replies. I noticed the manual says to inflate the tires to 16 lbs. not 12, so I'll add some air pressure. Pete, I had thought about the rims not running straight but you can imagine the look I'd get if I asked my wife to help out here.
720Deere
03-06-2006 05:07:05
 Re: 70 D rear end shakes in reply to Dan in Ohio, 03-06-2006 05:00:51
Jack up that side of the tractor and spin the tire with a block of wood sitting against the edge of the tire. You will quickly see if it is spinning straight or not.
Dan in Ohio
03-06-2006 11:51:37
 Re: 70 D rear end shakes in reply to 720Deere, 03-06-2006 05:07:05
Today I increased the air pressure to 16 lbs. and now it rides pretty smooth, just not as nice as my other 70. The tires are not loaded and my initial checks did not find anything out of the ordinary. Hopefully when its 70 degrees out those 6 ply nylon tires will smooth out even more.
