'37 JD A oil pump coupling
Rekabnivek
03-05-2006 16:32:49
While running my '37 A today the motor bogged down and cut off. Went to restart and all didn't sound well, unlubricated noise, in motor. Pulled crank case cover and slowly turned motor over, oil pump shaft not turning. I have found that the shaft coupling had slid down. Any suggestion on how old keep coupling up? Shoud I have a new one machined or just shim the coupling up with a washer with a square hole? Do they make a longer coupling?
Jason Mills
03-06-2006 05:49:04
 Re: '37 JD A oil pump coupling in reply to Rekabnivek, 03-05-2006 16:32:49
Just had this problem with my 37 A last summer. Be sure to look at the shaft in the pump drive gear. Mine had moved down for some reason in the gear. I put the gear and shaft in a press and pushed it back and then tacked it with a welder to keep it from moving again. you can adjust your gap by how far you move the shaft in gear. I also had to weld the top of my shaft up where it had rounded in the coupling then ground it back square to fit the coupling. Don't forget you can adjust oil pressure by the thickness of gasket under the pump plate. Good luck. Jason.
rekabnivek
03-05-2006 16:56:40
sgtbull
Not freezing here in southern VA, actually unusually warm today!! I believe the rod and main bearings are ok. Actually didn't bog down enough to cut off, I heard it boggind down and I shut it down. The coupling looks worn and has light cracks around top, just down to where the worn spots are. How much space should there be between the bottom and top shaft? Looks like about 3/4" on mine kind of hard to see in there! The shoulders on the lower shaft look fine, they don't look worn or mushroomed down.
sgtbull
03-05-2006 16:42:25
OUCH!... well, while you're in the motor, better drop the rod caps and see if they are damaged... wouldn't hurt to look at the mains too.. you may need more than an oilcoupler if it ran long enough to stop the engine...The coupler is still available from Deere, last I checked. You probably need to look at the top of the pump shaft and make sure it still has a shoulder on it.. its probably okay, but ck it anyway...The old coupler may be either seriously worn, or cracked. It was designed as a safety feature to keep from destroying an oil pump or camshaft in the event there was water frozen in the oil pump. Just curious, was it freezing weather where you live when you started it?... The oil coupler, like I said, is the least of the worries now...
