How much does it weigh?
NY Deere
03-05-2006 16:03:45
I have a 1951 John Deere model B that I need to move from Ohio to central New York. Can anyone tell me how much it weighs and would a UHAUL type car carrier trailer haul it safely? Thanks, NYDeere.
PeteNY
03-05-2006 20:34:38
 Re: How much does it weigh? in reply to NY Deere, 03-05-2006 16:03:45
NY, I don't know what the U haul trailers are rated at, but I regularly haul our '51 B on our #7000 2 axle drop deck which is essentially a car trailer with the deck lowered so that the fenders stick up. We are in the Binghamton area...where are you? How far into Ohio is the tractor? We occasionally are moving something from the Olean area of Western, NY...if you weren't in a hurry, maybe could work something out. Pete
NYDEERE
03-06-2006 13:29:49
 Re: How much does it weigh? in reply to PeteNY, 03-05-2006 20:34:38
Thanks to everyone that responded to my weight question. Pete, you had asked about where the tractor is. It is in Columbus Ohio and I need to get it to the Syracuse NY area by the 1st of May. Thanks, NYDEERE
Henry M
03-05-2006 16:37:29
NT
I needed to pick up a 3200 lb tractor one time and I thought of the u haul. I called and asked if their trailer could do it. They said no way, they would not rent it for hauling tractors.
So three days later I called and said I needed a car hauler. They said ok. Nothing in the contract said I couldn't haul a tractor.
Considering that an old car or pickup could weigh as much as your B, I would see no reason why it wouldn't work. also according to the stats your B could be under 4000, depending on model Etc.
The U Haul I used had the impulse brakes and I was favorably impressed with them.
Depending on the tow vehicle, you can find that data in the manual on what it is rated to pull. I routinely hook 10,000 on the back of my 3/4 in a 5th wheel config.
scott ind.
03-05-2006 16:10:58
4400# you need good trailor with brakes and it works my 3/4 ton hard but its 10 years old
good luck
