Fan shaft removal
Rutland
03-05-2006 14:41:00
I have a 1949 JD A ser. #645819 and I need to remove the engine. I'm at the fan shaft assembly point but I'm stuck here. I have the JD service manual, parts manual, I&T manual and 2 of the supposedly best " how to restore books". None of these really spell this out. The I&T manual talks about removing the fan shaft assembly and governor as a unit, I hope thats not the case. There are 3 castings that connect the fan shaft to the governor, there are 2 bolts connecting on the right side of the castings and a stud on the left side. If I free these up will all three castings slide forward on the fan shaft tube? What about the bevel gear on the end of the fan shaft. There is only about an inch clearence between the fan and the raditor, will that give me room to clear the gear from the governor? This is all new to me and I would appericate any advice you can give me. Thanks
Mike M
03-06-2006 05:09:10
 Re: Fan shaft removal in reply to Rutland, 03-05-2006 14:41:00
For block and head removal the fanshaft need not be removed. It's tight and you have to turn it just right,but they are designed to be removed this way if needed.
If you need to remove the fanshaft and gov. only than this can be done without removing too much. You can loosen up the hood bolts and jack it up high enough to get the gov. case to come out. Once the gov. case is out the fan shaft will slip out one side.
If you are going to keep the tractor I'd go through it all as once you look you can find alot of problems.
Rutland
03-06-2006 06:49:26
 Re: Fan shaft removal in reply to Mike M, 03-06-2006 05:09:10
Thanks Mike, I'm adding a relpy to F-I-T as to why I need to do this. Please give it look. Tim
F-I-T
03-05-2006 15:48:28
Rutland:
My first real "project" was repairing a '48 "A" that had sat in the weeds for a long while, so I've had about every part of one on the floor at one time or another.
On the fan shaft, if you don't want to remove the governor case, what worked best for me was to unbolt the radiator and slide it forward as far as you can, and put a piece of Formica on the fins so you don't bump the core as you push the fanshaft forward. You should have enough space to slide the fan shaft forward significantly, but the stud will be the sticking point. SO...once you slide the fan shaft along with the three castings forward (those are actually those are the laminations that form the ventilator pump and will stay a part of), you can grasp the stud with a vice grip and turn it out. This will give you extra clearance and you should be able to swing fan shaft clear.
Now, don't be too reluctant to remove the governor case. It's pretty straight forward as long as you mark gear teeth if you can't find a stamp, and if you remove the fan shaft and governor as a pair, you will be able to set the heel and lash of the gears and tighten things up a bit in the governor.
Now when you say remove the engine, do you have to remove the block? For that it is easier to remove the fan shaft, but if it's only the head, you can drop that out of the bottom.
Tell us what you are up against.
Frank
Rutland
03-06-2006 03:28:41
 Re: Fan shaft removal in reply to F-I-T, 03-05-2006 15:48:28
Frank,
Forgot to say that I will get back to you with an explantion as to why I have to remove the engine. Tim
Rutland
03-06-2006 03:21:24
Frank,
Thanks for the quick reply. This is just the kind of help I need. I hope you don't mind if I come back with some more question concerning this operation. Tim
F-I-T
03-06-2006 06:43:07
 Re: Fan shaft removal in reply to Rutland, 03-06-2006 03:21:24
No problem.
Rutland
03-06-2006 08:08:37
 Re: Fan shaft removal in reply to F-I-T, 03-06-2006 06:43:07
The reason I have to get at the engine is a good case of caveat emptor. I got the tractor off of ebay. It was located in Michigan, I live in Sarasota Florida. I took his word that it was in good shape. Engine had recently been re-built by a professional I was told. The tractor ran for crap. Just by dumb luck I discovered that the carb. was for a model B, not an A. I got a re-built model A carb. from Robert's and it started right up and ran pretty good. I soon found a small crack in bottom of the block that had been sealed by some kind of rubbery stuff but was starting to 'weep'. Some JB weld and piece of screen fixed that (for now anyway). While I was down there I saw that the lower left stud to main case nut was missing and the hole had been filled with RTV rubber. The block upper right stud nut was also missing and the broken stud had been painted over. After running the tractor in place for just a very short time I found a nut and washer on the floor. It had snapped off from the lower right stud. Right after that I found a nut and washer laying by the upper middle stud. Looking at the material you could tell that there was only litle 'fresh' metal that had finally fractured. These babies had been ready to go for some time. So it's 3 out of 6 that are broken. The parts catalog says there are 8 studs. Maybe the other 2 are on the sides where I can't see them. Obviously I don't run the tractor anymore. So thats why I need to get the engine off and hopfully get those studs replaced. I was thinking that if I supported the rear of the tractor frame on a good heavy duty dolly and inserted a support bracket between the fan shaft tube and the upper frame cross menber I could then remove the 3 bolts and 1 stud nut from the governor then remove the 4 bolts that connect the frame to the main case. Then I would be able to gently slide the the frame and fan shaft assembly free of the main case as one unit. Then I'd have access to the remove the engine block. Hows that sound. As an aside the compression is good, 100 psi per cylinder. Tim
Mike M
03-06-2006 12:42:19
 Re: Fan shaft removal in reply to Rutland, 03-06-2006 08:08:37
I'm not entirely sure what you want to do to this tractor ? You may not be either and are just in the what if phase ?
If you are going to have that block repaired or replaced then I would say that you are going to have to pull the engine apart. As in remove the head and the pistons and rods then the block. This all can be done with the fanshaft and frame and sheetmetal all undisturbed.
Now if you just want to leave the block alone or try a new patch witout tearing the engine apart,but want/need to replace the block gasket and the studs this can be done too. I have done a couple that just needed the block gasket and studs fixed. One had none left and the engine was just floating in there when running ! I made a stand for the front frame to support it.
Then unbolted the rods shoved the pistons forward,unbolted the fanshaft at the gov. case,unhook some wires and lines,unbolted the block and then the frame (have everything well supported)and basically just split it kinda like you would a "normal" tractor design.I rolled the back away from the front with a floor jack blocked under the flat spot for the starter I would think ? This worked very well to save alot of time and money just for a block gasket problem.
Or you could just get mad at it like I did my 720 Diesel "caveat emptor special" and tear it all down 100% and rebuild it back up right ? Or do like my late A "caveat emptor special" I got mad at it and parted it out ! I can't say for sure but I may of lost more money on the 720 D ? I still have it so it would depend on what kinda "offers" I get if I lost or not ?
Rutland
03-07-2006 04:02:07
 Re: Fan shaft removal in reply to Mike M, 03-06-2006 12:42:19
Mike, I'm glad to hear that I'm not alone in a trip down 'caveat emptor' road. I explained this trip to F-I-T in a previous post. I already have all the sheet metal and the tank off. I'm going to take off the raditor then remove the fan shaft, block up the main case and pull the frame forward, then remove the engine and see what I can do with all those broken studs and the crack in the block. I'm new at this posting and not sure if you can see my e-mail address, if not it's [email protected], F-I-T if you read this I hope you too feel free to contact me. Tim
Mike M
03-07-2006 04:41:56
 Re: Fan shaft removal in reply to Rutland, 03-07-2006 04:02:07
That sounds like it's doable. Many ways to skin a cat -so to speak.
Just think safety first and support everything good as it will get very unstable once that frame is loose of the main case.
F-I-T
03-06-2006 09:58:24
third party image
Okay, now I understand what you're after.
I would probably go about it this way:
Remove the radiator (in case you do have to separate the front frame at a later time, as those studs could be suspect, too, it be less risky). Remove the fanshaft to give easiest access to the block removal. This gives you the best look at those studs. Then slip of the head out the top, then the block. You can look the block over pretty well and probably will want to either have it professionally repaired if possible or find another block. Good compression or not, I wouldn't tear it down just to put a cracked one back in, but that is you call. Those blocks weld pretty nice with a rod I have b een using caled "Muggy Weld". Others use nickel rod, but I gavce up on that after finding the MUggy product. You can also braze them and since it is not a structural member or a pressiruzed system, you have a fair chance of getting it to hold coolant. After welding and cool down, I have put water in the water jacket with the block sitting face up to check for weeps. If it passes that test, I sit in a warm area, or heat it up with a heat lamp and then fill it with paint thinner or gasoline. If it holds that stuff back, it's probably solid.
You will want to inspect and likely re-set the heel and lash of the governor since you will be that close to everything. At least I would. You'll never get a better chance.
BTW, depending on your serial number, you may have 8 studs, or 6 studs. The latest ones were 8.
Frank
Rutland
03-07-2006 03:22:25
 Re: Fan shaft removal in reply to F-I-T, 03-06-2006 09:58:24
Frank, thanks for the gasket pic. I've got the 6 stud pattern. Sounds like my best bet would be to remove the raditor then remove the fan shaft. I'm not to comfortable taking the governor off, I don't think there is any problem with it. As far as welding the block goes I'd have to leave that to a pro. to do. And finding a good one could be a job in it's self. I'll keep you posted on my progress (if you don't mind). Tim
