4010 Diesel with blowby
Bill Young
03-05-2006 14:21:05
I am currently going to school for diesel mechanics, and I have a question for those who know more about this than I do. My dad has a 4010 diesel tractor. This last summer, it started to have a lot of blowby coming out of the blowby tube that comes out of the engine at high idle (2150 RPM's approx). When operated at 1500 RPM's or lower, you would get no blowby. It also had a bad knock at those high RPM's. Now, even at low idle (800 RPM's approx) there is a lot of blowby and knocking. In school, I have learned that blowby can be caused by a stuck oil ring, broken compression rind and when this happens, the oil gets near the top of the piston and burns causing carbon build up. And the piston gets scored from the broken ring because the got gases from combustion get down the side of the piston, and burn up the oil that is supposed to lubricate the liner wall. Am I correct in my assumption? Is there any other possibilities? Please give me some feedback so I know if what I am learning is worth it, and my dad is curious as to what is going on with his tractor, thanks for your help. Bill
JDknut
03-06-2006 03:54:19
 Re: 4010 Diesel with blowby in reply to Bill Young, 03-05-2006 14:21:05
You have it about right, and you are looking at a trip to Overhaul City and Rebuild County. With the knocking, I'd look at the bearings and crank as well.
twopop
03-05-2006 14:35:41
there is a possibility that the top compression ring on one of the pistons is broken and a piece of the ring has worked up thru the piston and is sitting on the top of the piston hitting the head at tdc.I have incountered this twice in 15 years of working on deeres.
Mike M
03-05-2006 14:33:58
In simple terms it is just worn out ! Time for an overhaul.
Bob
03-05-2006 14:30:00
Your theories sound good.
Can you borrow a diesel compression tester to see if the problem is with one cylinder, or if they're all worn and leaking?
