Antifreeze in oil of JD 50
Indiana Smith
03-05-2006 05:54:56
I bought a JD 50 project tractor with water in the oil. What is the most likely route of the water to the oil in these two cylinder tractors?
I warmed the engine and then did a compression test. 75 psi on both cylinders. Valves and rings are brand new. I popped off the valve cover and found that the lead washers were completely squeezed out from under the head nuts. Does this indicate overtorquing of the head?
I pulled the head. I do not see any obvious cracks. There does not appear to be any gasket adhesive used when the head gasket was installed. The I&T manual says to soak gasket in engine oil for 5 seconds and drain for one minute before installing. I have never heard of this before??? I thought you were supposed to use gasket adhesive???
I welcome any thoughts!
Mike M
03-05-2006 11:42:11
 Re: Antifreeze in oil of JD 50 in reply to Indiana Smith, 03-05-2006 05:54:56
That compression is kinda low ? Is your gauge working right ? Did you have the throttle open and the choke off so full amount of air could get in ?
Were the head bolts kinda loose ? I'd tried retorquing it before removing it,but since it's off go have it checked for cracks.
F-I-T
03-05-2006 07:15:28
IS:
I have some thoughts:
In order of likelihood, IMHO, headgasket, then head crack, then internal cylinder crack.
>>I warmed the engine and then did a compression test. 75 psi on both cylinders. Valves and rings are brand new. Compression sounds low to me. New rings and valves? Unless you are sure and the edge of the headgasket looks fresh, they could have fibbed. Or could it be a low-compression All-fuel engine?
No, not at all. The lead is meant to squeeze out so as to push in around the threads and form a seal. It will begins to ooze out as you approach probably some benign torque value like 40 pounds.
That was the preferred method in the old days with the old style gaskets, but today, I use Copper-Kote spray. Before that I used Permatex in the tube. Now that the head is off look closely for flaws and check it for flatness. A touch up lapping of the valves will reveal how "new" they are.
You are welcome.
Frank
zwr
03-05-2006 07:11:24
If the head is sound and was properly installed, chances are the leak is in the push-rod tubes in the cylinder block. Perhaps you can sleeve them, but it may be less costly and more certain to get another block.
It is normal for the lead washers to squeeze out. (They also squeeze in.)
Head gaskets do not take a sealant.
F-I-T
03-05-2006 07:17:59
 Re: Antifreeze in oil of JD 50 in reply to zwr, 03-05-2006 07:11:24
I don't think '50's had push rod tubes. At least there are no pictures of them in the parts book.
buickanddeere
03-05-2006 08:11:42
 Re: Antifreeze in oil of JD 50 in reply to F-I-T, 03-05-2006 07:17:59
Correct. Eliminating the pressed in push rod tubes was an upgrade from the B to the 50. When this engine was still assembled there should have been air pressure applied to the cylinders with the in/exh valves closed. This would have allowed hearing & or seeing air whistle into the crankcase, into the oil galleries or into the coolant system. Then applying 10 psi air pressure into the rad would have found more or verified suspected leaks. When it's apart it's time to read the part number on the pistons and purchase LP pistons if those are all-fuel. The cam and followers are likely ratty but it's cheap to have Robert's Carb freshen them up. The crank may as well come out to verify the crank bearing wear and if the oil seals have moved. The head & block will have to be magnafluxed at a machine shop. Odds are the valve guides have never been replaced nor have the valve springs been checked for fatigue after 50+ years of service.
Mike M
03-05-2006 11:38:22
 Re: Antifreeze in oil of JD 50 in reply to buickanddeere, 03-05-2006 08:11:42
Push rod tubes were eliminated in the later B's before the 50 came out. There are something like 3 head numbers that will all interchange from about 1941-1942 ? and up to the end of the B's some have the tubes some don't and one has a different oil feed and return passages and requires a different cast washer under the center stud.
