720 D Pony motor clutch
steve duplechin
03-04-2006 17:01:53
My clutch on the pony motor is slipping. I read the service manual and it says to adjust the clutch by turning the yoke on the inside of clutch housing. Do you shorten or extend the yoke to tighten up the clutch. Thanks for the help.
Kevin L.
03-04-2006 18:57:10
 Re: 720 D Pony motor clutch in reply to steve duplechin , 03-04-2006 17:01:53
i hope I'm reading you right but the yoke adjustment maybe for the timing of when the starter gear start turning. The adjustement for the clutch slipping would be the three bolt under the cover that has jam nuts on them. You loosen the jam nut, turn the one bolt one bolt head flat or 60 degrees set jam nut roll motor to next bolt and repeat for all three bolts, if it still slips repeat steps. Almost like adjusting the clutch on the big motor. Now for knowing when their no more clutch left I can not answer that one...
