Anyone ever had this problem
MATT VR
03-04-2006 09:18:14
I am going back togeather with my tranny on my 48B and i am having a really though time getting the cover that goes over the frist reduction gear back on. I remember when I took it off it was kinda tricky but I have tried for hours to find the right angle that it goeas back on with no success. Does anyone have any advice?
thanks everyone
Ben.So.Tex
03-04-2006 15:07:37
 Re: Anyone ever had this problem in reply to MATT VR, 03-04-2006 09:18:14
Remove right brake from tractor.
Hole cover over the reduction gear and intstall the back end, and then it Shoud give you some slack and clearance on the crank to get it back on. Hope this helps.
Their is not a lot of room or clearance to work with, It came off It will go back on. Ben
Ben.So.Tex.
03-04-2006 14:53:54
DO NOT FORCE IT. IT WILL BREAK>>>>>>>>>
It goes on and off with a little twist if I can find out some info in my books I will reply again. I had to take one off my 50 and it came off and on real easy following the direction. If you don't hear back from me go to your local dealer and ask them to copy a page of the instruction from the repair book.
Later Ben
Pappy
03-04-2006 11:14:44
When working on my "A", I made some dummy guide bolts to put into three of the holes in the casing. Bolts should be long enough to be removed when the other bolts are installed. It helps to guide the cover on so you can watch for the bearing fitting the cover. At least you don't have to deal with that cam bearing spring which can be tricky.
