Buying an A or B
farmalljosh
03-04-2006 08:58:47
I know of a tractor for sale. It is either an A or B john deere. It is one of the earlier 'styled' tractors. 1940-1946?. The guy says it runs. What should i look for when purchasing a tractor like this? I know a decent amount about mechanics and engines but i have never bought a 2-cylinder tractor before. What are some specific things to check? How would you start it? i am used to the Farmall tractors, but i am starting to like the johnnypoppers.
Thanks.
sgtbull
03-04-2006 15:04:14
 Re: Buying an A or B in reply to farmalljosh, 03-04-2006 08:58:47
while you're under it, take a look at the drawbar mounting bolts... make sure the drawbar hasn't been welded to the rear axle housing or that the bolt holes are "wallered out". crack the drain plug on the crankcase...shouldn't be any antifreeze in it... Run the tractor a while and look at the antifreeze.. shouldn't see any oil in it. Take a good look at pto shaft and make sure it isn't twisted. Check the radiator for damage or repair...if there is a lot of crud at the bottom of the tubes, don't be surprised when you clean it away if the radiator starts leaking around the base of the tubes. Has the hood been "cut" for the exhaust? what shape are the grills in? Are they repairable or all screwed up? Ck the manifold "ears" where it bolts to the carb...and the carb flanges. Look at the upper water pipe for obvious repairs or an inordinately long upper hose. They frequently rust out. Does it have lights? Are they working and in good shape? Lights are expensive. Seat cushions if a later model? Gauges? Those are expensive too....best recommendation... get a friend who knows tractors and take him with you...two people will see a lot more stuff than one....BUT REMEMBER...these things are 50 + yrs old and there will be things that need attention...you buy based on what you can afford to fix....
Mike M
03-04-2006 13:15:45
Crawl underneath and look at the bottom of the cyl. head and block for possible freeze cracks. Engine off,try to rotate the fan blade and see how much slop it has. A real loose one may have gov. gear /bearing problems. 1/4"- 1/2" may be normal. Engine off; Also snap the clutch in and by hand grab the pulley and try to rock it back and forth. Any play here that doesn't turn the crankshaft is wear in the clutch splines.
farmalljosh
03-04-2006 10:16:58
Thanx steve for the advice.
Steve Smitth
03-04-2006 09:59:18
Some of the things I look for, besides starting and running it. Drive it in all the gears. Listen for noise and make sure it shifts OK and doesn't pop out of gear. Check the flywheel for loosness. Check the clutch. Should engauge and disengauge with a nice pop. Check the power troll / power lift. Check the PTO make sure it engages and turns. Look for obvious oil and water leaks. Make sure the radiator has water and doesn't leak. Check the stearing for loosness.
