'37 JD A noise in governor
Rekabnivek
03-04-2006 06:16:00
Just wondering if there is any other way to get the backlash closer on the fan gear in the governor housing than the JD recomended shimming gasket? I don't think that this will help mine, I have about 3" of play athe the end of the fan blades.
Thanks
mbptractor
03-04-2006 07:02:55
 Re: '37 JD A noise in governor in reply to Rekabnivek, 03-04-2006 06:16:00
John T is correct about the gears and shims. Have you seen the gears? do they look sharp? You could try the end cap of the govener first. pop the 4 bolts out and see how thick the gasket is and make a thinner gasket.that may not take care of the nose but will tighten up the fan.First take off your magneto and mark it some how and put on last because once you pull that end cap off it spring loaded and you may not get the mag linned up and you could break your mag.
John T
03-04-2006 06:36:06
Rek, that sounds like a ton of slack, if the bevel gears are worn down so low they are sharp enough to shave (seen em like that) Im afraid if they are set closer she will whine n squall something even worse. Have you adjusted BOTH shims? i.e. the fan shaft set PLUS the governor end bearing cap trying to get their heels to mesh up??? The governor end bearing cap shims would bring the gears closer while the fan shaft shims make the fan gear move forward n backward so the gears heels line up. Once the fan shaft is shimmed for proper heel alignment, then see if the governor shaft can be shimmed/unshimmed to bring them deeper into mesh to reduce backlash, but if too tight then also whine bad unless or until they wear in some.
If those gears need replaced you need a matched set regardless if new or if you can find a good used set and after installing a used set mine whined a bit until they wore in then settled down.
This isnt my area of expertise so I look forward to what the mechanics have to say
Ol John T
