10 x 15 front tires for a JD 720
One big JD 720
03-03-2006 11:05:08
Hi, I have a wide front JD 720 D standard and want to put on big front tires - maybe 10x15 tire. WHere can I get rims for this and how well do these go on the tractor - do they fit?
Need more floatation - my tires sink in too much in loose ground!
Thanks!
430WLPG
03-04-2006 16:08:56
 Re: 10 x 15 front tires for a JD 720 in reply to One big JD 720, 03-03-2006 11:05:08
I have a 730Lp row crop with 11L-15's on it with the rims reversed and they work fine,I'm sure on a STD. tractor they should work fine also. Just go down to your farm supply store and buy two 8X15 wheels and go.
johndear
03-03-2006 16:16:59
I have 9.50L-15's on peanut trailer rims (8x15). No clearance problem. Looks good works good. I am sure the 'correct police' would have a fit though.
Mike M
03-03-2006 19:52:23
 Re: 10 x 15 front tires for a JD 720 in reply to johndear, 03-03-2006 16:16:59
The "correct police" probabaly never ran them on a farm. Alot of them have to be modified with the wider tires up front to keep going in the field. JD should of known this and offered them as an option.
Leon J
03-03-2006 14:16:45
I can't help much on your particular model, but I would suggest that you make sure you have enough room to ensure you don't rub on the levers at the top. I put 7.50/16's instead of 6.50/16's on a 2240 and then I found out they were too wide. I had to reverse the rims and have been told that that is hard on the wheel bearings. Good luck.
