DEERE X 585 WHEEL HOP WHEN PLOWING
ANTHONY CAFIERO
03-03-2006 10:59:04
I have a X585 tractor which is outfitted with a 54 inch blade and rear suitcase weights for plowing snow. There seems to be a pronounced front wheel hop at most speeds ( 2 and 4 wheel drive) and I can't seem to find the cause(s). Any suggestions would be appreciated.
jd b puller
03-03-2006 18:44:35
 Re: DEERE X 585 WHEEL HOP WHEN PLOWING in reply to ANTHONY CAFIERO, 03-03-2006 10:59:04
Do you have the original tires on there? What size are they? (Exact size on the tire)
Henry |J
03-03-2006 16:31:08
Anthony
If you are sure it is getting out of front wheel drive and it still hops that should elimanate drive train wrap up due to mismatch of tire size or something.
Next thing i would do is jack up each front wheel, and if you can turn them that way rotate them and see if the wheel is way out of round. Just a thought for checking.
buickanddeere
03-03-2006 11:04:50
What is the tire pressure and plys? It could be winding up with a ripple in the side wall then springing.
