620 crank removal
fender
03-03-2006 07:57:41
does anyone have any tips on removing the crank spacer or oil slinger on the left hand side?
Been There
03-03-2006 08:26:48
 Re: 620 crank removal in reply to fender, 03-03-2006 07:57:41
After loosening the right (pulley side) bearing housing, we carefully bumped the crank to the right and the slinger will be pushed free. It shouldnt be too tight on the crank, it just sits inside the bearing housing enough that it doesn't want to move easily.
BushogPapa
03-03-2006 18:22:53
 Re: 620 crank removal in reply to Been There, 03-03-2006 08:26:48
I don't think you have to loosen the Rt side (clutch-side) bearing...just to remove the slinger...
I am sure I changed mine on my 630 without touching the other side...but then, I did change the flywheel-side bearing at that time, too...
I found the oil delivery "Gasket" (O-Ring) had cold-flowed into the oil passage and stopped oil delivery to the bearing... Had to change the Rt side Main Bearing, as it had starved for oil, too..same reason.. Ron..
