Bringing an L back to life
Randy Trentham
03-03-2006 04:52:47
Recently purchased a J.D. L that has not run in 12-15 years. What are some of first steps to do to get it running. It is not stuck and starts with a hand crank. Thank you
tsmith1499
03-03-2006 15:00:27
 Re: Bringing an L back to life in reply to Randy Trentham, 03-03-2006 04:52:47
Take the mag to someone and let them go through it. It's not that expensive and will save you a lot of headache. If you can, check the compression. I bought an LA that had been sitting for years. It was not stuck, but when I tried to start it I found out the rings had collapsed from siting so I had virtually NO compression. This will also give you an idea as to what to look forward to. If you are going to restore it, buy the books for it so you can help your local Deere Parts man out. Looking parts up for these old 2 cyl. isn't as easy as looking parts up for the newer ones. If you can give him part numbers he will be more likely to help you out when you really need it.
Mike M
03-03-2006 05:58:23
I'd crack all the drain plugs loose and let the water run out. If the oil looked really nasty maybe start with new oil. Get it to spark,put gas in it (if it's gunked up carb. may need gone through first then use an auxillary tank)then try to crank-er-up. More than likely you will need to pour some gas in the cylinders,or if you have a pulley belt it up,you may end up pull starting it. These uprights don't like to suck the fuel up into the cylinders after a real long nap.
