JD 2750 leaks oil from Load Control Shaft
ol' guy
03-02-2006 18:27:36
Perhaps more detail than you want, but it started leaking heavily in June '05 and was repaired-- new shaft and kit of bushings, seals, etc. After very little use it started leaking again in December '05 and was fixed again by the dealer (new seals, etc.) and backed in the shed. It was not used since, but last week it was dripping out the right side, and had a slower drip on the left. It would make a spot about 8 in. in diameter on a clean piece of cardboard within an hour. I certainly don't know what to do, and the dealers service mgr. it not sure. Any and all suggestions appreciated.. Thanks in advance.
jcraft3
03-25-2006 09:49:41
 Re: JD 2750 leaks oil from Load Control Shaft in reply to ol' guy, 03-02-2006 18:27:36
Have the same exact problem as you. Did you ever fix it? I have replaced the bushings, seals, and o-rings. any recomendations?
feelnrite
03-03-2006 08:03:49
I am the one that has the 2955 that has been leaking. I have replaced everything and worked on it 3 times and it is still leaking. I have new seals now but havent put them in yet. JD has a new seal with a new part number and the seals are blue and made different. They were having trouble with the old ones leaking in cold weather. Now that is has warmed up here my old ones arent leaking as bad but will still change them out.
RedJD
03-02-2006 20:19:48
There is a aftermarket kit available that uses o-rings along with the seals.I just can't remember the name of the company that sells them.I read about them in Green Magazine.The article said they worked really good.If I can find that issue I will e-mail you.You might try contacting them at
402-643-6269.If I remember correctly the article stated that John Deere dealers sold these aftermarket kits under a JD part number.
Glen in TX
03-02-2006 21:42:03
 Re: JD 2750 leaks oil from Load Control Shaft in reply to RedJD, 03-02-2006 20:19:48
Ok try this one...
Glen in TX
03-02-2006 21:30:15
Boling has other ones but been reading here lately all of them leaking on models like your 2750 also. Still have to get bushings from JD. Check back a few pages and someone mentioned JD had some new seals? You need to check the wishbone too and make sure all the slack is out of it too with new pins or bushings and shims if needed. That is usually what knocks new seals out right away.
feelnrite
03-03-2006 08:07:00
 Re: JD 2750 leaks oil from Load Control Shaft in reply to Glen in TX, 03-02-2006 21:30:15
Hey Glenn in Tx. what do you mean the wishbone. Is that the play on the shaft after you put the arms back on. How much play should there be?
Glen in TX
03-03-2006 13:13:43
 Re: JD 2750 leaks oil from Load Control Shaft in reply to feelnrite, 03-03-2006 08:07:00
I wasn't sure to recommend Boling for these or not? I'm just confusing them with larger models like 4755 and 4955. lol. Completely different load shaft setup.
Glen in TX
03-03-2006 09:17:30
Ignore the wishbone comment. I was thinking of older models. Yours has the load sensing shaft with splines to arm.
Glen in TX
03-02-2006 21:32:01
hmmmm link is no good anymore ??
