JD 425 won't start
BrianTa
03-02-2006 18:26:42
Hi,
I have a 1996 JD 425. I went out this spring and tried to start it, and it ran for about 4 or 5 seconds then stopped. It now won't start. I have replaced the spark plugs, fuel filter, and carb solenoid - nothing. Each spark plug is sparking ok. If I remove one of the spark plugs, dip it in gasoline and put it back in, and then crank the engine, it fires a time or two and then stops fireing.
I took off the carb and looked it all over, made sure the jets were open, etc., replaced the gaskets and reinstalled - but all to no avail - still the same deal. It looks as though it is not getting gas - but the bowl is full... I am not a carb expert, so maybe I missed something... I don't know.... Any ideas or input would be appreciated.
Thanks in advance,
-Brian
Lindon Metheringham
05-02-2006 14:29:08
 Re: JD 425 won't start in reply to BrianTa, 03-02-2006 18:26:42
fuel pump in gas tank is shot.
Brianta3
03-03-2006 16:09:51
Thanks for the reply!
It turns out that the plastic timing gear on the cam has sheared off all of its teeth. The water pump gear (which is also plastic) was blasted away as well. I've got the engine all torn apart and have the pieces on order. I have decided to replace all of the plastic gears in there while I am at it - just as a precaution (only cost me an extra $10).
Thanks again for you help.
-Brian
jgc
03-03-2006 14:36:32
I haven't worked on 425s but I'd be re-checking the fuel system. If it fires reliably every time you add fuel into the cylinder, I'd be looking at the carb very carefully. The small passages inside the body may be blocked.
Fuel in the bowl doesn't tell you the full story. Was the fuel treated with fuel stabilizer before it went unused for a long time?
I worked on a friend's outboard that had been serviced by another friend of theirs. It wouldn't idle smoothly or develop any power.
They insisted it had fresh gas in it, but the tank smelled like turpintine.
In went the fresh fuel, away went the boat!
