2010 sleeves
jd plowboy
03-02-2006 16:51:04
does anyone know where i can get a new or good used set of sleeves for a jd 2010 gas.
jdemaris
03-03-2006 06:09:07
 Re: 2010 sleeves in reply to jd plowboy, 03-02-2006 16:51:04
As of six months ago, the deck was still availble from Deere - I bought one. If you get looking for used, a 1010 diesel deck is the same as a 2010 gas.
TylerARK
03-03-2006 05:29:02
I have seen a few that we have torn down with cracked sleeve decks. Most were cracked around the top of the sleeve where it was welded to the deck plate. Some others had small pin holes eat into the sides of the sleeves from electrolysis.
Tyler
billde
03-02-2006 20:04:48
The only way I know of is to have them magnafluxed at a machine shop.
There is an add on this website a fellow has some 2010 parts, don't know what he has, 816 586 2841 Mike in Kingston Mo.
jd plowboy
03-02-2006 17:40:34
i think the #1 sleeve is cracked. it had a cracked head on it and bought another head and when you fill with water and spin starter it blows water out sparkplug hole. it looks like it has a crack in the sleeve. are there any ways you can check sleeves for cracks.
billde
03-02-2006 17:25:47
Your 2010 doesn't have conventional sleeves, it has a deck with sleeves attatched. Unless yours is damaged, you have the deck bored by a machine shop. Pistons are available here on this website.
