Gear shift knobs off -- @^#*#^!!!!!!!!!
Larry5681
03-02-2006 15:47:19
I bought new gearshift boots for my 2020 but can't get the knobs off! I even had a pipe wrench on them this afternoon and didn't do anything buy chew them up. Do I just break them off and buy new ones? Anyone have a suggestion? Thanks in advance.
Dave Sherburne NY
03-03-2006 16:08:45
 Re: Gear shift knobs off -- @^#*#^!!!!!!!!! in reply to Larry5681, 03-02-2006 15:47:19
When I tried to get the knobs off my 47 CO-OP
it appeared to be impossible. Someone suggested
I put the boots in hot water and they would slip over the knobs Tried it and they did.
jd51mt
03-03-2006 07:05:34
Larry,
You might want to try a strap wrench with a piece of pipe on it. Sears sell them for around $20 and you get two different sizes. One time I was helping a friend rotate his tires and I kept breaking off the lug bolts, after about the third one he told me that it had left handed treads instead of right handed. After that I didn't break any more ha ha.
MIke
HenryM
03-02-2006 17:19:23
Fernan
That is truely ingenius. The last couple of knobs I took off looked like my wife's hound had been gnawing on them.
I hope I get a chance to apply it someday - or maybe I hope I don't.
Fern(Mi)
03-02-2006 16:57:32
How to remove a shift lever knob!
How we got the knobs off a couple/three 1850 Ollies. So, what if they are the better shade of green, LOL�. I just had to put that in. We�ve also a couple JD�s.
(1). To take our Shift lever knob off we carefully drilled a hole in the flat wide side of a 2�x4�x20� or so in length. NOTE: It may be necessary to drill the shift lever hole size put a hair sized larger than the knob. This size you may determine for yourself after you�ve read the rest of my explanation or instructions.
(2). The first hole drilled, through the 1 �� edge of the 2�x4�, I drilled a couple 3/8� holes the full width of 2�x4�, one on both sides of the first (knob sized) hole.
(3). I sawed the 2�x4� down the middle through the hole.
(4). Wrap a piece of inner tube over the shift knob.
(5). Over the inner tube using two 3/8� x 4�(?) bolts clamp the 2�x4� tight over the rubber cover knob.
(6). Slowly, carefully commence to use the 2�x4� as if it were a wrench handle and start to turn the knob off.
(7). This effort may have to be repeated two or three times loosening and retighten the 2�z4��s to loosen the knob to finish removing it by hand. Good Luck
Fernan in Shorthorn country
