1936 A rear wheels
old
03-02-2006 08:29:56
Has any one ever heard of or seen a 1936 A with pressed steel rims instead of the spoke type. Would they be what came on it new or did some one take them off something else and put them on??
Thanks
Duane Larson
03-02-2006 16:53:10
 Re: 1936 A rear wheels in reply to old, 03-02-2006 08:29:56
old,
Pressed steel wheels were not an option from the factory for unstyled John Deeres. Pressed steel wheels were first used when wide-base tires became available in 1939 for the 1940 model year. After that the pressed steel wheels were available but no hubs to mount them to the axle.
However, best as I can determine about 1947 Deere did make malleable iron hubs available for pressed steel wheels, with 10, 12, and 15 splines. Part numbers which may be stamped in the hubs are A3523R for the 10 spline, A3524R for the 12 spline, and A3248R for the 15 spline. All three hubs used the B1961R hub clamp.
The malleable iron hub replaced the cast hub.
old
03-02-2006 17:12:03
 Re: 1936 A rear wheels in reply to Duane Larson, 03-02-2006 16:53:10
Thats about what I had been thinking. I called a guy about a 36 A he has for sale and when he said pressed wheel I figuged I didn't want it becuase it would be to far off the mark
Duane Larson
03-02-2006 20:22:34
 Re: 1936 A rear wheels in reply to old, 03-02-2006 17:12:03
old,
Well, I sure haven't seen many unsA with pressed steel wheels so there couldn't have been many of the malleable hubs made. But if you decide to follow up, I think I would want to look carefully at the hubs as they are the key. Probably someone is making hubs today for tractor pullers?
old
03-02-2006 21:38:18
 Re: 1936 A rear wheels in reply to Duane Larson, 03-02-2006 20:22:34
Another reason I have backed off is he said the head was off and a few other things. And I have found that even if they say its all there that one little thing that cost $300 is always missing. LOL
Jason D. Wahl
03-03-2006 06:06:26
 Re: 1936 A rear wheels in reply to old, 03-02-2006 21:38:18
I would be interested in the 1936 'A' if you are not. Let me know. Thanks! 830-660-4278 or 830-221-1111.
old
03-03-2006 08:09:28
 Re: 1936 A rear wheels in reply to Jason D. Wahl, 03-03-2006 06:06:26
This A is in Missouri and the guy wants $800 for it.
DSK
03-02-2006 15:01:28
If the tractor still has the 10spline rear axles and the 10 spline JD hubs, you can assume the tractor has correct wheels. I don't know if this was ever a factory installed option, but I do know the pressed wheel and 9 bolt hub were available through parts for someone updating to rubber tires. I have never seen an original tractor equipped this way.
