Unstyled A rear rim width
Big Al's Acres
03-02-2006 05:10:17
Hello,
I have a 1935 Unstyled "A" with flat spoke rear cut down rims. The rims are SHOT and need to be replaced. I do not know if the bad rims are even the proper width. I would like to know what the correct width is so I can replace with proper size. Should I have 36" diameter rims?
Thanks...
Al
EARL-IL
03-02-2006 08:13:00
 Re: Unstyled A rear rim width in reply to Big Al's Acres, 03-02-2006 05:10:17
AL, Make sure the replacement rim has the right lip on the rim to fit the aftermarket tire. I have 11x36 rim on my 35 "A" with a old style 12x36 tire.Some of the new tires are recessed in the bead area and they don't fit the old style deep lipped rim. Earl
DSK
03-02-2006 07:33:30
You could replace it with almost any rim width you want, but a 10-36 would perhaps be the best choice. If you use the 36 inch rim, your spokes should still be long enough to weld to the new rims without having to extend them. You would then be running a 11.2-36 tire. Personally, I've always thought the unstyled A's look a little better with a 12.4 or 13.6-38, but that's up to you, with cutoffs your options are many.
Duane Larson
03-02-2006 11:21:31
 Re: Unstyled A rear rim width in reply to DSK, 03-02-2006 07:33:30
Al,
Unstyled A's came with 6.00S-36 rims, whether demountable rims on cast wheels, or spoke wheels. The rim width was 6". The tire size for this rim was 9.00-36. Wheels with 8.00T-36 rims were used on the G. These rims and tires were of a "conventional" size, so named after the wide-base tires and rims became available for use in 1939. Conventional rear tires are no longer made, only wide-base tires are available. The wide-base rim and tire recommended for conversion on the A was the 8W-36 rim with a 9-36 tire - which corresponds to a 9.5-36 tire available today, or a 9W-36 rim with a 10-36 tire - which corresponds to an 11.2-36 tire today.
Big al's Acres
03-02-2006 08:38:16
Thanks for the ideas on tire size. Do you know what rim width should work with the 11.2, (6" rim?) or the 12.4 (8" rim?)? I am thinking of using 8" wide rims, if they are proper for a restored tractor, that is trying to be original.
Al
