A. J.D. WONT RUN, HELP
piston
03-01-2006 15:52:11
CAN SPRAY brakecleaner in cycl will run, carb. has gas coming thru it , new denny carb.i no , but ,gas run out drain, took off air oil bath run hanger down thru it its clear, been setting up 3 years,runs good till cleaner runs out , been long time since i worked on one , kind of lost here
usaidit
03-03-2006 15:27:43
 Re: A. J.D. WONT RUN, HELP in reply to piston, 03-01-2006 15:52:11
Had a simular problum mine turnsd out to be the ignation switch terminals were corroded. No sure sign yours is the same but claening them is real easy and no expence
Tom Windsor
03-01-2006 16:52:12
Do it 1 step at a time:
1. Compression...Check it--although it sounds like you have compression.
2. Ignition--Make sure coil or magneto is delivering fire. Then Check wires. Remove plugs and clean or replace both plugs and wires. 3. Fuel Good clean fuel please...3 year old gas will kill you.
4. Timing--then of course, all of the above must get to the right place at the right time--if you have any trouble with this. Speak up.
little h
03-01-2006 16:23:59
Sounds like a weak spark and/or old gas is not enough to burn. get new plugs, points, wires and some new gas then try it. try not to use too much brake cleaner as it will thin the oil on the cylinder walls and may cause more harm.
