4020 gas...4088 hours
rboulware
03-01-2006 11:33:46
Found a 1965 gas 4020 with 4088 hours on it, which the seller SWARES by and the hour meter DOES work, I may add. He say nearly EVERY thing works on this tractor. I told him to do a dyno test on the tractor.
They want 6100.00 for it, what do you all think? I though it was sort of high. It is a REALLY nice looking tractor from the photos. Is that alot of hours for a gas tractor (4088)? Should I steer clear, I sort of like the thing. What do you all think? Its a wide front of course.
Romey
03-01-2006 13:59:14
 Re: 4020 gas...4088 hours in reply to rboulware, 03-01-2006 11:33:46
The original tachometer on this tractor would have a red needle. You will see alot of units with"original hours" and have a white needle tach,which would indicate replacement at one time. It sounds like an original tractor, though.My 4020 gas has 7000 hours,and I paid $5500 for it, 7 years ago. I belive it had been overhauled at some point because it runs darn good yet. They use alot of gas, but are still a good yard tractor.
rboulware
03-02-2006 09:49:12
 Re: 4020 gas...4088 hours in reply to Romey, 03-01-2006 13:59:14
Well well well...it has a white needle not a red one. SO....it must have been replaced at some point. Also intresting not the machine only made 76 horsepower on the dyno which I KNOW is low FOR sure...so we might not know the whole story on this machine.....things that make you go HHHHmmmmm ..... .Just muddys the watr even MORE..
Mike M
03-02-2006 10:15:47
 Re: 4020 gas...4088 hours in reply to rboulware, 03-02-2006 09:49:12
Did it have alot of blowby ??
I have never dynoed ours but the specs. on the early ones are somewhere near that I was thinking 80 something HP ? NOT SURE but they are for sure alot lower than a good running diesel that make 100 hp.
It would be easy to gain or loose some hp on those gassers with some timing and carb. adjustments.
Mike M
03-01-2006 12:04:31
Ours has 6000 hrs on it and still runs fine.I suspect it is original ?
Check to see if it has the original top link ,side panels,pto shield and all the little stuff as that adds up real fast if missing. If it's really nice and good tires and such I don't think the price is out of line as we paid about that 10 years ago for one.
rboulware
03-01-2006 15:48:16
 Re: 4020 gas...4088 hours in reply to Mike M, 03-01-2006 12:04:31
MAN!! I wished I could send yall pictures...MAN!
Mike M
03-02-2006 05:59:48
 Re: 4020 gas...4088 hours in reply to rboulware, 03-01-2006 15:48:16
Be there when they dyno test it. Make them run it awhile to make sure it doesn't die.
