JD 4050 transmission light comes on at idle
Willy P
02-28-2006 19:12:03
On my JD 4050 with powershift,when the tractor is idling below 1000 rpm's the transmission light comes on,I have changed the filters and oil and the little metal filter and it has not helped,could there be a leak internally or a weak transmission pump? It has been doing this for a while,What should I do next? Thanks
G/MAN
03-01-2006 07:30:06
 Re: JD 4050 transmission light comes on at idle in reply to Willy P, 02-28-2006 19:12:03
Check transmission system and lube pressures.
