630 compression???
TIMAR
02-28-2006 17:59:41
What is the compression supposed to be on a 630? Mine only has 75#S No. 1 and 100#'s on No. 2. Runs fine, but I am replacing the manifolds and I thought if it needed it, I would take the head off and check the valves or put oversize rings in it since I was this far.
DickD
03-02-2006 12:08:45
 Re: 630 compression??? in reply to TIMAR, 02-28-2006 17:59:41
TIMAR; I think Machinery Man makes a lot of sense. You are past the hard part of removing the manifold. Why spend $75 for a valve grind set if runs well like you say.
Mike M
03-01-2006 08:14:30
I would for sure pull the head to do that manifold and do the valves too.
Machinery-man
02-28-2006 19:44:58
I don"t know your reference to oversized rings. You might consider replacing rings, however if it does not smoke I would do the following. Take rocker arm off, insert air into cylinder and lightly tap you exhaust valves. This would free up any carbon build up and reseat valves. You might go with lower pressure say 30-40 lbs to start with and then raise on up. This will make sure that valves are sealing. Then I would install rocker arm, adjust the proper clearance, then light the tractor up under a full load situation. I would give it a good work out then check the compression again. If still week might consider valve and ring job.
TIMAR
03-01-2006 08:28:52
 Re: 630 compression??? in reply to Machinery-man, 02-28-2006 19:44:58
What is the compression supposed to be? I have already taken the manifolds off and am just waiting on the heat valve to put in the new manifold.
