Correct gages for '40A
Dean Lydey
02-28-2006 17:47:54
I'm going to Polk's auction this weekend to look for some goodies for my '40A project. I need new gages (oil pressure and temp). There appears to be lots of stuff on the market and I really don't know what's correct. What should I be looking for? Color seems to be important for an accurate restoration. What should I expect to spend?
Thanks.
P Browning
02-28-2006 18:56:31
 Re: Correct gages for '40A in reply to Dean Lydey, 02-28-2006 17:47:54
Dean: Check on the oil gauge over at www.jdhpubs.com, then select "gauges". For the JD "H" tractor, the oil pressure gauges changed from 43 to 44, and I will be they changed for your 'A" also, so you will be looking for the earlier version. If in doubt, give Jerry Trcka a call -- his number is listed on my site, and he will positively know. The temp gauge did not change for the "H" during its run from 39 thru 47. (PatB)
DickD
02-28-2006 18:40:04
You can spend from $35 to $70 depending on what you want. You can even have the old ones rebuilt for $50 to $60 per gauge
