Unusual front tires on 3010
Al in Wisconsin
02-28-2006 16:02:47
I recently purcaesd a 3010 diesel, narrow front. The size of the front tires is 6.00-14, apparently originally equipped that way. I need to replace one of the tires, but have not been able to locate a three-rib tire in that size. Does anyone know of a supplier for that tire, or should I switch to a more common size?
Maark
03-01-2006 07:00:43
 Re: Unusual front tires on 3010 in reply to Al in Wisconsin, 02-28-2006 16:02:47
The 1st 3010's used the 14" front rubber along with 36" rears. Several years ago I was looking for some 14" front rubber for my GP as that was what the front steel was cut down to. All I could find at that time was ribbed implement tires, 6.70x14 if I remember correctly.I might have one of those triple rib. I will check the size.
Glen in TX
02-28-2006 19:59:51
I doubt those were original. A look in a parts book would tell you if they were a option. I'm looking in a 3010 diesel row-crop utility operators manual and it says front tire sizes were 6.50-16 or 7.50-16. A implement, trailer or auto tire may be all you can find in a 14 ??
