Compression range on a 50
DanJD50
02-28-2006 15:30:53
Can anyone tell me the factory compression range for a model 50 JD?
DSK
02-28-2006 20:30:15
 Re: Compression range on a 50 in reply to DanJD50, 02-28-2006 15:30:53
Gasoline, 118. LPG,172. All Fuel,91. Just a word about compression tests. The engine should be warmed up to normal operating temperature. Then the engine should be cranked with the throttle in the wide open position. This will give you an accurate compression reading.
