730D ES - Which Battery?
Charles Beavers
02-28-2006 12:08:55
I have a 1959 JD 730 Diesel with electric start. I think the batteries are weak and there are four 6 volt batteries in a series (24 volt). I want to replace them with two 12 volt batteries in a series. What type or group battery should I use and what would be the proper or minimum cranking amps?? Are there any precautions I should be aware of when disconnecting and reconnecting the batteries??
Thanks in advance...Charles Beaverson
buickanddeere
03-01-2006 05:43:15
 Re: 730D ES - Which Battery? in reply to Charles Beaverson, 02-28-2006 12:08:55
The battery specs should state " vibration resistant". Check the wiring connections against the electrical manual. It's common to find swapped polarities etc from a previous tinkerer.
730 mike
02-28-2006 21:04:31
I agree with barnrat the biggest you can fit. I put interstate batteries in my 730D ES. Starts great even when its real cold here in Wisconsin even though I rarely run it in winter. If you want to know what size I put in e-mail me and I'll go look and get back to you.
Mike
barnrat
02-28-2006 19:14:15
The biggest 12 volt batteries you can fit in there. I get my batteries as take outs from fleet trucks. Used but still tons of life in them and free if you have a friend that works in the shop.
