'46 A hard to start in cool weather
Nancy Howell
02-28-2006 12:05:02
My '46 A has always been hard to start when the weather got cool. Pulling the spark plugs and spraying a shot or two of "engine fast start" would usually do the trick, but lately he's really been hard to start. Last w/e it took 5 times of pulling the plugs and spraying fast start before we got him to fire. Any suggestions? BTW, plugs have less than 10 hrs. on them.
Glen in TX
03-01-2006 15:13:50
 Re: '46 A hard to start in cool weather in reply to Nancy Howell, 02-28-2006 12:05:02
That black fouling from unleaded gas and ether isn't going to clean off so replace them. Use metallic core wires and non-resistor spark plugs with a magneto. Autolite 388 & 386 are resistor types and not recommended and carbon core wire is a no no with magneto. Usually the higher the number is the hotter the plug is. Champion D21 are recommended in manual now days and D16 would be colder and D23 hotter. Cold originals= Champion D16, AC C87, Autolite 376.
Mid range= Champion D21, AC C88, Autolite 377, Denso L14-U. Hotter= Champion D23, AC C88L, Autolite 378. If it was sitting long before you got it the carb probably does need cleaning and kit again.
DickD
03-01-2006 23:15:59
 Re: '46 A hard to start in cool weather in reply to Glen in TX, 03-01-2006 15:13:50
Thanks Glen. I wrote that all down the last time you explained it but my filing system isn't what it could be lol
DickD
03-01-2006 12:03:46
Nancy; I use a Champion D23 plug which is 2 steps hotter than it calls for. I am not necessarily a Champion fan, but that is what's available in my area.
Mike M
03-01-2006 08:21:06
How are you shutting it off ? You aren't choking it to stop it are you ?
What brand of spark plugs do you have ? I would use autolite # 388 I've had good luck with those.
Nancy Howell
03-01-2006 09:34:34
 Re: '46 A hard to start in cool weather in reply to Mike M, 03-01-2006 08:21:06
We shut it down by pulling the gas lever all the way back. We also shut the valve on the gas line after the engine has quit. Carb was rebuilt about 10 yrs ago, and while the tractor hasn't be used heavily, it probably wouldn't hurt to have it done again. The tractor generally fires right up when the temp is over 60. A hotter plug in the winter may be the answer. I know absolutely nothing about plugs, can you suggest a hotter plug? BTW, when I pulled the plugs, they had black fluid on them, but no build up as they are fairly new - maybe 10 hours on them. Magneto was replaced about 10 yrs ago, too.
Randy Varilek
02-28-2006 14:58:47
Check your carb. Had the same problem with an A and when i took the carb off, i founs that the choke shaft was stuck and the little spring didn't have enough power to move it. Freed up the shaft with al little WD 40 and it has started great ever since.
DickD
02-28-2006 12:53:21
To have to pull the plugs every time you start the tractor means something is not right. I would start by making sure I had a strong blue spark. Sometimes if the carb is not set right, it wont start. Float level is another thing to check. Use a set of plugs a couple of steps hotter than the specified plug.Just a few things that might help.
TEXASJ
02-28-2006 12:49:04
IF nthe fast start you are reffering to is ether, STOP!!!!! !!!! Its like coacaine for your engine with the ratio it has.
Glen in TX
02-28-2006 12:36:58
They make electric heaters that go in where the coolant drain plug is that might help some. You may have fouled plugs by now and just need a new set of plugs or wires and tune up. If starting fluid is needed I just shoot a bit at air cleaner stack. We have put straight 20W oil in our air cleaners in winter also.
