720 bearing
r.g. montgomery
02-28-2006 10:00:48
To change out the bearing and race on the sliding gear shaft in the transmission does the tractor have to be split. thanks in advance for the help
DSK
02-28-2006 14:07:02
 Re: 720 bearing in reply to r.g. montgomery, 02-28-2006 10:00:48
No, the tractor does not have to be split to remove the sliding gear shaft,bearings or gears. You will however have to remove the flywheel and the gearcover from the left side of the tractor, and the belt pulley and first reduction gear cover from the right side. You also have to remove the shift quadrant and lever assembly from the top of the case, after which you can take out the shifting forks and the rails they slide on. You will then have access to the sliding gear shaft. No you don't have to split the tractor, but it still is alot of work to get to it.
