Flushing crankcase Hyd.
Greg A
02-28-2006 06:45:16
I recently purchased a JD M from my father-in-law, he had always used non-detergent oil in the crankcase because he was afraid of oil sludge loosening up and causing engine damage if detergent oil was used. The manual calls for flushing the crankcase, touch-o-matic and transmission with kerosene, is this a good practice or will you run a risk of loosening up sludge that may later cause damage. Should I stay with non-detergent oil or flush and begin using detergent oil. Also our local JD dealer suggested using Hy-gard in the touch-o-matic instead of motor oil, what is your thoughts.
Mike in shendoah valley
02-28-2006 13:18:23
 Re: Flushing crankcase Hyd. in reply to Greg A, 02-28-2006 06:45:16
Greg- friend's advice is good,although I dropped the oil pan on mine-only takes 5 minutes-then you can scrub it up. kero or diesel in trans works well-I did the final drives too and drove it around for 5 minutes or so, hy-gard is fine for hyds-you can flush w/kero and run for a minute or so,drain and fill w/ hy-gard,but to be sure that all kero is drained from pump,lines,valves, I would change the hy-gard twice in a row
