Injection pump
Mike Treasure
02-27-2006 21:00:14
Have a JD diesel 70.How do I retard timeing on injection pump.Thanks
buckeye al
02-28-2006 14:20:21
 Re: Injection pump in reply to Mike Treasure, 02-27-2006 21:00:14
Be sure you lok into those windows straight on and not at an angle. Being off from looking at an angle can make a fairly notable difference. Maybe I doubt myself too much but once I think I have 'em set, I roll the engine over & check 'em again.
donmyeil
02-28-2006 07:20:21
Remove the flywheel cover. Put engine on no.1 tdc. at the 9:00 position you will see tdc and inj on the flywheel. A corresponding mark (line is hard to see so scrape the case if needed.) on the case. Remove the top cover on the block. You will see the inj. pumps. Each has a "window" with a line on it. With flywheel on "INJ". The marks on the plunger and pump body should line up.If not adjust the push rod to the pumps. Do the same for no.2.
Mike Treasure
02-28-2006 09:01:04
 Re: Injection pump in reply to donmyeil, 02-28-2006 07:20:21
THANKS SO MUCH
