70 DIESEL /720D STARTER BRACKET
Gwiz
02-27-2006 07:26:48
I was wondering will a 720D/730D electric starter bracket fit a 70d.I have a friends 70 that he wants to convert to electric start.I know they make a conversion kit but have not priced one yet ..... ....are they big bucks?? let me know please.
mjbrown
02-28-2006 04:59:08
 Re: 70 DIESEL /720D STARTER BRACKET in reply to Gwiz, 02-27-2006 07:26:48
I'll bet it will cost close to a grand to make that conversion. bracket
starter
2batteries (big ones)
cables & switches
12v won't work well I've tried it.
GPULLER
02-27-2006 08:20:37
Yes the starter bracket from a 720/730 will fit on a 70. There is a bracket on ebay right now. I have not priced a conversion kit. When I converted my 720 I bought most of the parts on ebay, it took me over a year to get all the correct parts.
Gwiz
02-27-2006 11:17:17
 Re: 70 DIESEL /720D STARTER BRACKET in reply to GPULLER, 02-27-2006 08:20:37
What have those brackets been bringing for a price?I am just starting this venture so I am not up on the prices for 70 stuff.I know the G stuff well the parts are getting higher and higher.
GPULLER
02-28-2006 08:31:51
 Re: 70 DIESEL /720D STARTER BRACKET in reply to Gwiz, 02-27-2006 11:17:17
Most brackets are bringing anywhere from 150-300 bucks. I got lucky and bought mine for 150. I also used the correct water, intake manifods, and crankcase breather. I have appox 300 in the correct Deere parts. Had a 12V starter laying around but had to buy a nose cone and pinion gear. Used a GM alternator, 2 group 34 batteries 750cca that fit in the pony start battery box. It will start until the temps get to 20 degrees, I don"t have a need to run it when its that cold anyway. I spent a bunch of money on pony coils, points, condensors, carb kit I have not regreted the conversion one bit.
Gwiz
02-28-2006 12:11:37
 Re: 70 DIESEL /720D STARTER BRACKET in reply to GPULLER, 02-28-2006 08:31:51
Thank you all for the input and info on this project.I guess it will be the owners choice on the amount of money he wants to spend.The tractor is really rough looking but they bought it brand new in 1955.So it has a history so I will see.
buickanddeere
02-27-2006 20:16:08
Before the time the starting batteries are replaced the 1st time. The electric conversion will cost more than freshing the cranking engine. As long as some donkey didn't run the engine with coolant leaking into the crankcase oil. All a cranking engine needs is fresh coils, cleaning the entire fuel system from tank to carb internals and maybe a new water pump seal. Most conversions are not neat or complete and devalue the tractor. If they insist on butchering the tractor. At least gather up every cranking engine part, protect from rust, label the crate well and place in a safe place where it won't get lost or forgotten. I'll bet this tractor is also missing the fenders, to cover and the original seat. The #1 problem with cranking engines is the people using them. Have a look at the KW ratings of the Delco MT42 and MT50 starters. They can not match the torque at 200 cranking rpm that a cranking engine can. The electric may well roll the engine over but it can not match the speed. A 12V system can not afford any short cuts or economizing of any component. A 24V system is really required for satisfaction. Price the 24V batter box, charging system, 12V fuel sender, light upgrades, two 1000CCA minimum batteries, 0000 cables and swaged connectors.
