4020 brakes stuck
Jeff Oliver
02-27-2006 07:13:11
We have a 4020 gas with hydralic brakes. One side is sticking. We can let the pressure off at the axle and they will unstick so we are thinking it is in the valve that the brake pedel goes to. Dad was reading a repair manual and it said something about recharging this valve with nitrogen? if you take it apart, any clues to what that means and can you get a tool to do that if you need to?
Any other ideas on fixing it are appreciated too:)
Thanks!
G/MAN
02-27-2006 07:30:43
 Re: 4020 brakes stuck in reply to Jeff Oliver, 02-27-2006 07:13:11
The nitrogen accumulator shouldn't have anything to do with the pedal sticking. That problem will be in the valve itself, and it's not uncommon. The rubber boots get torn, water gets in the valve and seizes it up. The nitrogen accumulator stores hydraulic pressure so you can still have a couple of "power" brake applications in an emergency if you lose the engine or hydraulics. The brake valve will likely need to be removed and rebuilt.
Jeff Oliver
02-27-2006 10:23:36
 Re: 4020 brakes stuck in reply to G/MAN, 02-27-2006 07:30:43
Ok thanks! That is what I was looking for! We haven't taken any of it apart yet but that sounds alot better than the nitrogen thing. Yea the boots were cracked pretty good so that sounds right.
txgrn
02-27-2006 17:36:58
 Re: 4020 brakes stuck in reply to Jeff Oliver, 02-27-2006 10:23:36
I took mine apart last year having never done it before and only having the I&T Manual for guidance. Bought the kit from JD for a reasonable price.
It went really well and was straight forward. If you are the least bit mechanically inclined you should do just fine.
Mark
Jeff Oliver
02-27-2006 20:21:44
 Re: 4020 brakes stuck in reply to txgrn, 02-27-2006 17:36:58
mechanically inclined is not the problem as I do alot of tinkering and we have the I & T manual for it. I was concerned about the nitrogen thing since we haven't gotten into it yet and I wanted to make sure I had everything I needed. I think we are going to pull it into the shed this week and tear into it. Other than that and the carb needs a little adjusting this thing is in great shape!
One thing, this is a gasser, I have been told it will suck fuel bigtime, this true?
txgrn
02-28-2006 18:39:32
 Re: 4020 brakes stuck in reply to Jeff Oliver, 02-27-2006 20:21:44
Well I didn't have all that stuff. Just a box that the two brake pedals attached to on the right side of the tractor. Saw nothing that had to do with nitrogen or an accumulator or any of that. Only thing connected to this was hydraulic fluid (in and out) from the pressurized distribution system.
Sorry,
Mark
Mike M
02-28-2006 04:54:52
If you have a 4020 with a brake accumulator then it must be a side console model. Post the serial number to verify this. And since it is GAS that is a VERY RARE COLLECTABLE tractor so make sure it stays in original form. And yes they do like to suck up the gas when loaded heavy.
