J-D 70 fuel filler neck rubber gromets?
Big Al's Acres
02-27-2006 05:54:47
I will be putting the sheet metal back on my 70 in a couple of weeks and would like to find new fuel filler neck rubber gromets, my tractor was an "all fuel" so I need one for the gas and one for the main tank. I checked at our local J-D dealer, to no avail.
Thanks, Al
DickD
02-27-2006 16:45:48
 Re: J-D 70 fuel filler neck rubber gromets? in reply to Big Al's Acres, 02-27-2006 05:54:47
I have a new one laying here for my gas 70 that I got from Deere. The part number is R82873.
DSK
02-27-2006 09:46:38
If you have an early 70 with the filler neck near the center of the hood, the grommet you order fromDeere will not fit. The early 70's had a larger diameter filler neck than the later ones. If you have one with the left side filler,the one from JD will work. It is solid black and has FUEL printed 3 times around the outside rim. If anyone knows of another one that works on the early tractors, let me know.
Big Al's Acres
02-27-2006 10:31:53
 Re: J-D 70 fuel filler neck rubber gromets? in reply to DSK, 02-27-2006 09:46:38
Sounds like a bit of a solution is available for the main fuel tank filler, now lets deal with the secondary tank for my all fuel application. I have spoke again with my buddies at the local J-D shop, they did dig around and find the replacement part suggested. They did not give me any hope for the secondary fuel tank with a smaller neck.
Regards, Alan
Big Al's Acres
02-27-2006 09:13:55
Hey,
I will let you guys know what I come up with for fuel neck gromets from J-D from a 4020 or 4430. It bugs the devil out of me to put sheet metal back on with gapping openings around the filler necks. Kinda looks naked to me.
Al
Big Al's Acres
02-27-2006 09:13:35
Hey,
Al
billyiron
02-27-2006 06:33:19
Im pretty sure One from a 4020.4430,4450.4455 an your 70 are the same,,go back and grab him by the shorthairs and say hey look scooter,I want a filler neck gromet dang-nabbit,,,billy
Big Al's Acres
02-27-2006 07:22:52
 Re: J-D 70 fuel filler neck rubber gromets? in reply to billyiron, 02-27-2006 06:33:19
Billy...Thanks, I WILL try the short hair trick and see if I can get some parts support for my 70.
Al
Mike M
02-27-2006 07:58:51
 Re: J-D 70 fuel filler neck rubber gromets? in reply to Big Al's Acres, 02-27-2006 07:22:52
Those could fit the same size hole ?? But I am almost for sure they will look differently.
Glen in TX
02-27-2006 08:21:00
 Re: J-D 70 fuel filler neck rubber gromets? in reply to Mike M, 02-27-2006 07:58:51
I seem to remember the later ones all being red? Guess you could paint it black ?
Mike M
02-27-2006 10:08:03
 Re: J-D 70 fuel filler neck rubber gromets? in reply to Glen in TX, 02-27-2006 08:21:00
Red with FUEL written all over them so you didn't put antifreeze in there since they were clear up front.
