720d Hyd pump
StuBC
02-27-2006 03:28:30
I had a bit of a leak at my pump last summer in my 720D so I would like to try and fix it. It is a slow drip when not in use and when under pressure it would squirt some oil.
Anyway, I have the parts and service manuals and have studied it some. I see the bolts to come off. Is that about it to get it down? And to put it back in once I re/re orings etc.? Push it back in and bolt it down?
Glen in TX
02-27-2006 04:19:42
 Re: 720d Hyd pump in reply to StuBC, 02-27-2006 03:28:30
Inspect things for wear while torn down also. Pump drive shaft, splines, key ways, gears, pins, bushings, etc.. The I&T and JD SM2011 shop manuals give you tolerances for wear. JD SM2022 manual if you have custom powrtrol. Some have mentioned in the past about some of the bushings not being available and you might have to make those if needed.
