4010 vs 4020 !
Scott(MO)
02-26-2006 19:56:38
Hello, I'm new to this site and I don't know much about JD's. We have mainly AC and Oliver and Ford. I know about IH as I use to work for a dealership. But, I have only worked on one JD (4020) in my life. I have been thinking about later on down the road ( when the finances are better) getting another tractor for round baling and was looking at JD because of ease in getting parts as compared to Oliver. I have a pretty good idea about 4020's horsepower , but was wondering about the 4010. What was the years they were produced? What is the HP on a 4010? Are many parts interchangable with the 4020? How much difference is there between the two?
Thanks.
Scott
jimmy ray
03-16-2006 19:35:46
 Re: 4010 vs 4020 ! in reply to Scott(MO), 02-26-2006 19:56:38
I have a diesel 4010 that my father bought new in about 1962. I think the original hp was approximately 76. It was extremely reliable and very good on fuel. It would probably pull anything that you would want to pull. I spent many hours as a teen on that tractor. It is more comfortable than most. The only problem we had back then was burning out a clutch by pulling up stumps. Not the tractor's fault as it wasn't designed to be a dozier.
dp in nd
02-27-2006 19:33:35
If you have a good JD parts man, he can still get you the greasable throw out bearing. On the 4010, when you change the pto to the other speed,do not force it with the bolts because you will break something up by the front pto shaft and you can fix it without spliting it, I did it,was not fun. Dale
PJBROWN
02-27-2006 17:30:36
I know of two farmers who still have 4010's around just to run their ag baggers. The ag baggers have hydraulic ran feed tables. Both farmers claim that the 4010s will run anything hydraulic better than any newer JohnDeere that they own. I don't know why ,but that's what they both claim.
Fern(Mi)
02-27-2006 14:57:03
I can't tell you which tractor is the better. We've more Oliver's around here than JD's. Three 1850's, two Perkins diesels, one gas: one 4010 diesel (power packed), one 4020 gas, a 2150 Oliver plus others. Parts aren�t any harder to get for one brand mentioned over the other. For us old handycrappers the 1850 Oliver�s are easier to work on without splitting to get at every thing what may need repair; otherwise likely hidden inside the John Deere. The 4010 PTO engagement requires unforced engagement; putting in the bolts when the PTO shaft has been FULLY ENGAGED BY HAND FIRST!
As to which shade of green does any particular job easier, both brands have offered or shown me my preferences. But those ideal differences are my own. That�s the way of our green.
Fernan
gwece
02-27-2006 06:42:02
I pull a NH 850 round baler with my 4010 and it handles it fine on some pretty rough ground here in Southern Illinois. I also have a 4020 but it sure seems to like the fuel. I also have a MF 1100 and an AC 180. My all around favorite is the 4010....maybe that's just because I've had it for so long and am so used to operating it, but it is a real good sized, all around use tractor that is good on fuel economy.
barnrat
02-27-2006 04:59:40
Not to belittle JD but you'll pay a premium for a Deere. Sometimes double what you can buy another brand of tractor for. I do agree Oliver parts are hard to find, but not impossible. Those Olivers are still good tractors. Your Ford, AC or IH brands are just as easy to find parts for as a Deere. I work on all brands of tractors and get just as good a parts service from other brands as I do from JD.
buickanddeere
02-26-2006 20:55:17
It never hurts to have a look around before opening one's wallet. Before writing a cheque for the 4010/4020, how about just finding out the price for a new 4020? Deere sells them as 2WD & 4WD models with a decent optional cab. They are the model 6403 & 6603.
Greg H. WV
02-27-2006 10:06:08
 Re: 4010 vs 4020 ! in reply to buickanddeere, 02-26-2006 20:55:17
BuickandDeere,
are the 6403, and 6603, both still four cylinder turbo models? If they are similar to pappy in laws 6400, that I've used allot, I would rather have a late model 4020 in regards to rider comfort, and power. Plus I don't like the electric controled PTO,{that quits working from time to time}, and his tractor just feels awkward compaired to the 4020. The 6400 is easier on fuel, but in all fairness to this tractor, it is only supposed to be about 85 horse, but the 6400 just wont lay down and lug, pulling heavy loads, it just falls on its ear. Just my oppinion, I'm sure others have theirs. Have a good day, Greg H.
buickanddeere
02-27-2006 21:17:20
 Re: 4010 vs 4020 ! in reply to Greg H. WV, 02-27-2006 10:06:08
Another thought. After a couple of thousand hours usage and the difference in fuel efficiency.The Nebraska tests tell the story. There will become the point where the 6603 will cost less than the 4020 just calculating initial cost and fuel use alone. Then throw in repair costs for a 34+ yr old tractor over the next 5-10 years.
buickanddeere
02-27-2006 20:19:08
Have a look at the Deere web site, it will answer your questions and more.
Randy Varilek
02-26-2006 20:53:59
the 4010 had the 380 engine and the 4020 had the 404 although it is hard to find a 4010 that hasn't had the 404 sleeve and piston kit installed. also the 4020 had the powershift transmission option which is very useful for round bailing. generally the 4010's are a lot cheaper and generally just as sound as the 4020's. I do remember the 2 4010's that my dad farmed with being very hard on clutches due to throwout bearings locking up.
Bob
02-26-2006 20:16:05
Here's a recent thread:
Link
Another link:
http://www.greencollectors.com/dbs/forty-twenty/
