4840 or 4640? that is the question,,
gjdman
02-26-2006 14:27:50
im thinkin of buying a 4840.. yes i would like to get about 200 horses out of it... everyone tells me the 4640 is a better tractor.. since i am planning on turning it up a little i figured the 4840 was the better choice since it was closer to the 200 mark already. Im not a powershift fan.. but i was willing to deal with it. what are the pro's and con's to each? and which one has the better reputation?
Thanks guys as always
730virgil
02-27-2006 10:36:10
 Re: 4840 or 4640? that is the question,, in reply to gjdman , 02-26-2006 14:27:50
have you looked at 6030 ?
G/MAN
02-27-2006 07:35:52
I don't really see how the 4640 could be considered the "better" tractor, as the two models share a lot of the same components. When dealing with Power Shift trannies, the 4840 is obviously the better choice for higher horsepower, as it uses 15 springs in the torsional damper (which mounts to the flywheel and drives the tranny). The 4640 only has 12. The 4840 was sold as the "deluxe" tractor, and had as standard equipment features that were optional on the smaller tractors - Power Shift, Sound-Gard, etc. I wrote an article for Tractor Shop Magazine a while back detailing the differences in the 4640 and 4840. There should be back issues available.
Gunner
02-26-2006 20:00:59
4840 would be the way to go. I have a 48 and think there is one more difference. I am pretty sure they have a different injector pump. I think the 46 uses the same as a 4440. There are a few other things I have ran into when ordering parts.
Lary
02-26-2006 18:06:08
48 and 46 are about same tractor except the 48 has larger fuel tank making the tractor 6 inches longer, the oil cap. is slightly larger and I believe the cooling systen is a couple qts larger to acc. the 20 extra hp. the only prob. I can think of associated with the 48 was some rear end gears that were too soft. A recall solved that problem long ago. get the 48. Lary
ricedaddy
02-26-2006 17:30:34
I have had both, and still have a 4840. Basically there the same tractor, except,4640-twist out at 156.3, lift 1563 lbs, has the same 466c.i. in both tractors and the same tranny, the 4840 twist 181 on the pto with a the same 466 c.i. engine. The reason I like the 4840 better is more power, lift, holds more fuel by about 20 gallons. Maybe Bubba can tell us why the 4840 has had more problems. I have mine turning about 205
good luck
Ron
Jonfarmer
02-26-2006 15:46:06
How about a 4955 or a 4960?. Those are both 200hp.
Jonfarmer
02-26-2006 15:53:21
 Re: 4840 or 4640? that is the question,, in reply to Jonfarmer, 02-26-2006 15:46:06
Also, the 4850 is a 200hp tractor.
BUBBA-N-AL
02-26-2006 15:07:21
4640/powershift good tractor 4840 seem to have problems ?????
