70 wide front steering
Blast52
02-26-2006 12:30:39
I have installed an adjustable wide front axle assembly on my 70D after removing the original "Roll O Matic" pedestal. My question is which of the 4 bolt holes does the "pitman arm"(?)
assembly get installed and is there any special piece that I may not have as it appears to me that the "pitman" may not be meant to bolt directly to the steering cylinder base.
I have the power steering service manual and the tractor service manual but there is no info to help me out in either of these.
Thanks in advance for any help.
DSK
02-27-2006 06:26:02
 Re: 70 wide front steering in reply to Blast52, 02-26-2006 12:30:39
I have a 70 with a square tube wide front. The steering arm is bolted to the rear set of holes on the bottom of the pedestal. There were 3 different versions of this front end and this is the early one. There is no spacer used between the steering spindle and the bellcrank. On my 730 however, that has the late version of the same front end, and that does have a spacer used here.
Blast 52
02-28-2006 14:27:21
 Re: 70 wide front steering in reply to DSK, 02-27-2006 06:26:02
DSK
Thanks for your help.
I suspect that the axle assembly. I bought may have been intended to be used on a 730.
The assembly. does bolt up to the tractor, but I guess I must source a spacer. Thanks for your help.
Blast52
