1943 B QUESTIONS
amo
02-26-2006 06:31:11
WHEN REMOVING THE HOOD DOES THE FUEL TANKS COME OFF ALSO?
WHERE CAN YOU PURCHASE NEW FUEL LINES?
Maark
02-26-2006 10:10:20
 Re: 1943 B QUESTIONS in reply to amo, 02-26-2006 06:31:11
You can buy the fittings from several places to make your own lines. Roberts Carb, Detwilers in Wi. K&K, also from Deere. New lines from Deere are very expensive. I needed the oil line that hooks in the bottom of the block on a 45 B for a guy, JD wanted $52.00 that line is only about 6" long. I made a new on out of brake kine and ferral fittings from NAPA for $5.00
DickD
02-26-2006 07:37:49
The tank comes with the hood, then there are 2 brackets that each have 2 bolts in them. Once those are removed,then you can remove the tank from the hood.
Buster
02-26-2006 07:21:19
I think Sharps has new fuel lines, their web site is, www.oldjd4u.com
billyiron
02-26-2006 07:01:23
yep the tank comes too,fuel lines I dont know,,we have made some from brake lines, or went to salvage yard and found some,,billy
