42 jd A
frank van den d
02-25-2006 18:28:20
i have more than 1 service man.1 says to check valve clearance hot,the other says cold.which one is rite & what should the clearance be.they both say 20 thou.i much prefer the cold setting.i set them cold at 20 but it sounds a bit noisy to me.this is my 1st jd tractor exp.so what do i know.thank you.
Duane Larson
02-25-2006 19:41:57
 Re: 42 jd A in reply to frank van den dorpel, 02-25-2006 18:28:20
Frank,
The owner's manual which came with your tractor is about the best service manual you can find for it. It does not say anything about hot or cold, so that would assume cold in my book. Quoting:"Remove tappet cover on front of cylinder head and turn flywheel until all tappets are free. This occurs 1/8 turn of flywheel before left-hand exhaust valve opens. Adjust tappets by tightening adjusting screws until there is no shake in levers, then back off adjusting screws 1/3 turn. Be sure adjustment is locked tight. Turning the adjusting screw back 1/3 turn gives 0.020-inch valve clearance."
That was Deere's recommendation and I would go with it.
