4430 dump valve?
Neil Vonnahme
02-25-2006 06:37:17
hi all, just wondering if anyone had some knowledge to share i run a john deere vac planter on my 4430 and running the hydraulic vac will overheat my hydraulics. I've inqiured about putting a return dump valve on my 4430 but can never get a straight answer if that is possible or not. anyone know if there is a way to install? thanks
Neil Vonnahme
02-26-2006 19:53:59
 Re: 4430 dump valve? in reply to Neil Vonnahme, 02-25-2006 06:37:17
thanks guys thats what i was looking for.
Mike w J
02-25-2006 15:30:35
on the back of the tractor by the serial no tag that plug that a 1/2 in drive socket extension fits into it can be took out and put in a pioneer hyd. or JD fitting to dump oil backin without causing extra heat that would be caused by dumping lots of oil back threw the regular outlet These were used on hydraulic reset plows model 2500 and others any JD dealer should be able to find it for you
dp in nd
02-25-2006 08:12:53
Should be no different then when I run hydra. motors on my tractor. put both hoses into one outlet so the oil goes forward to the cooler and pump.So you do not get a lot of back pressure on your planter,put a pineneer coupler on the plug on the side of your control valve for the return oil.That way when you shut it off the return is still open.
