45 loader cylinder leaking
Fred from MO
02-25-2006 05:16:33
I have one cylinder leaking at the front seal on my 45 loader. The cylinder shaft looks pitted from rust and is rough, and I believe this cut the seal. I am debating if I should buy a whole new cylinder, or just repair the seal use emory cloth on the shaft and hope it wont leak, or ??? Open for suggestions.
sgtbull
02-25-2006 17:42:31
 Re: 45 loader cylinder leaking in reply to Fred from MO, 02-25-2006 05:16:33
I tore mine down w/ the same problem. I went to a local supplier and got new orings....didn't bother to replace the ram packing. It cost me about $5.00 total. Haven't had a leak since, and I can leave the bucket in the air for a week w/ no leakdown. I did polish the rams up w/ emery paper. It takes a lot of the protective finish off, but I try to always leave bucket down when not in use in damp weather so the arms are retracted and in oil. I'd try that first since its so cheap. If it doesn't work, you can always spend more cash on another option.
Randy G.
02-25-2006 11:08:38
I rebuilt the cylinders on my 45 loader. They run around $90 for both kits from John Deere. Mine where leaking past the seal due to shaft pitting inside. Seems to have corrected the problem. Randy
Henry M
02-25-2006 05:23:34
Fred
I would try the emeorycloth and new leal thing, it worked for me but I guess it just depends on the magnitude of pitting
Mike M
02-25-2006 05:23:10
Find a local hyd. cyl. shop and buy some sections of NEW chromed rod stock and new packings. Those ends are just crossdrilled and held on with roll pins so they can be done without special equipment.
